SZack
8 years agoDoes the A5 version of a MAX V have different timing than an I5?
For the MAX V (EPM570 in this case) does the automotive part (A5) have different timing specs than the industrial temp part (I5)? I have a customer doing a design in a MAX V and it passes timing if...
SZack
8 years agoHi Calvin,
My bad – the part is a MAX V – the 5M570, not EPM570.
The device is failing timing in TimeQuest, not the actual board when the I5 part is specified, but it passes timing when the A5 part is chosen. If you want me to send you the project I can. You’ll see the difference in the TimeQuest results depending on whether the I5 or A5 part is chosen.
I sent this email on 9/30 but haven’t seen a response so maybe you didn’t see it.
Steve
