Seadog
7 years agoDoes QPP support incremental compilation?
It appears that Quartus Prime Pro (ver. 18.0 or later) does not support incremental compilation. The documentation does not discuss incremental compilation, and the Design Partitions Window does not...
KennyT_altera
7 years agoQuartus Prime Pro uses a different synthesis engine thus having a different structure compare to Quartus Prime Std. They will no longer have incremental compilation, you can still set the design partition windows in pro but it will require you to study a different document. You can study this document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-block-based-design.pdf if any thing that you don't understand from this document, just give me the question and the page number will do. I will answer it here.
