17 years agoDoes PLL VCCA require isolation if PLL isn't used?
Hi Folks, I'm currently designing a board with an EP1C3T100 that doesn't use the PLL. When checking the Cyclone manual for board layout best practice it recommends isolating VCCA. I quote - ...
17 years ago --- Quote Start --- Even if the PLL is not used, the VCCA power must be connected to a 1.5-V supply. The power connected to VCCA must be isolated from the power to the rest of the Cyclone FPGA. --- Quote End --- In my opinion, the second clause doesn't refer to the first. Standard VCCINT bypass should be sufficient in this case. As an additional remark, if you intended to use the PLL though: VCCA isolation mainly means separate bypass caps and a filter (R or ferrite) to VCCINT. If you place the caps (I have typically 1n + 100n) directly between VCCA and GNDA, there's no particular purpose of 1. a separate plane, 2. a VCCA island, 3. thick traces.
