MK_ABQ
Contributor
4 years agoDoes Arria F series support JESD 204B?
I would like to know if Agilex F series FPGAs support JESD 204B IP?. If no, then would like to understand why?
- 4 years ago
Hi Sir
You can just launch Quartus Pro software, go to Assignments --> Device, at column 'Tile' will shows the available tiles for each device.
Screenshot an example as below.
MK_ABQ
Contributor
4 years agoHi SKBeh,
Thanks for your response. From the second link you have given, it mentions that JESD204B IP is supported by Agilex devices (E-tiles). Attaching image below.
Where can I find if my F-series device has E-tile?. For instance, I am seeing different tiles : R-tile, F-tile, P-tile, H-tile, and E-tile. Is there any document which explains which tiles does F-series devices has?
