RXie
6 years agoDoes 1SG085HN2F43E2LG must need to connect the PMBUS?
Does 1SG085HN2F43E2LG must need to connect the PMBUS? Is it necessary to connect pmbus pin only if tail is - V?
Rahul_S_Intel1
6 years agoHi ,
Does 1SG085HN2F43E2LG must need to connect the PMBUS? >> Yes as per the recommendation,
Kindly find the explanation.
Intel Stratix 10 devices will not configure or function correctly if the core voltage is driven by a non-PMBus compliant regulator with a fixed output voltage
page no: 5
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-pwr.pdf
- RXie6 years ago
Hi
我看了下这个文档,应该是-v的才必须接PMBUS,-L的应该可以不接对吧?
