15 years agoDividing two N-bit signed binary (with fractional bits) in Quartus
In my design, I am required to divide a signed 16-bit binary, say A, with another signed 16-bit binary, say d. Both inputs have decimal and fractional bits. The denominator d is actually a posi...
15 years agoIf 'd' has too much of a range and doesn't fit reasonably into a lookup table you may want to try serial division. A serial divider works on a single bit of the numerator per clock cycle so the calculation time is determined by the numerator width. So it doesn't have the pipelining performance of say lpm_divide that can handle a calculation after every clock cycle once the pipeline is warmed up but it's fairly small and hits a relatively high Fmax. I don't know if I have my implementation of it around still but it's a pretty easy thing to implement since it's based on the same techniques as you learned long ago in school called long division.
Here is a link that shows how it is implemented in "C2H friendly" C code: http://www.altera.com/literature/hb/nios2/edh_c2h_optimization_design_files.zip It's easier to implement in verilog or VHDL so don't let the macro madness in the .zip file scare you :)
