DisplayPort MST Failure
Hello Adam,
May I know what is the FPGA device?
- AdamKao6 years ago
Cyclone 10 GX
Thank you.
Adam
- Deshi_Intel6 years ago
Hi Adam,
I have taken over this case back
It's good to finally able to communicate with you directly without going through the dFAE.
There are few questions that I would like to clarify with you.
- All the while we are taking about Arria V FPGA, your design files that DFAE shared with me earlier is also Arria V. Just curious why you suddenly mention about Cyclone 10 GX FPGA ? Can you clarify again which FPGA that you are using in your project development ?
Below is also some follow up questions from my previous enquiry that I didn't hear back from you yet.
- You shared with us 2 MSA log file before (MSA_SST.txt and MSA_MST.txt)
- Have you reviewed you MST stream 0 and stream 1 design to ensure there is no design difference particularly on the clocking side ?
- Also does your MST design meet Quartus Timequest design timing closure with positive margin slack ? Is your stream clock frequency correct ?
- Do you have a chance to try other refresh rate between 60Hz to 120Hz to see if it works ? Like eg : 75Hz ?
- For the btc_dptxll_stream_set_pixel_rate = 297000. It's meant for 2200 x 1125 x 120Hz. 277272 setting is meant for lower refresh rate. Just to confirm you are not running 120Hz refresh rate with 277272, right ?
- From the earlier MSA log, I can see DisplayPort link training failed and DP data rate reduced from 5.4G to 2.7G. Do you have DP Aux transaction decoder equipment like Unigraf DPA-400 to decode Aux log transaction to help us understand and isolate what's the issue with the "bad DisplayPort link training process"
Deshi
Hi Deshi,
Yes you are right we are talking about Arria V FPGA and I am using the Arria V for the DP MST project. Sorry I was confusing you. Because there are several projects are going and one of the project is using the Cyclone 10 but NOT for this project that we are discussing. I have answers for your questions below:
- Regarding the MSA log file (MSA_SST.txt and MSA_MST.txt) I shared, both of them are the same hardware and the same FPGA design. The difference is :
MSA_SST.txt = connecting output to a SST monitor.
MSA_MST.txt = connecting output to a MST monitor.
- Ensure MST stream 0 and stream 1 design are the same. I create a simple pattern generator in the design and then connect to the two input of DP IP. That is to say two input of DP IP for two stream are fully identical.
- MST design meets Quartus Timequest design timing? Yes, but in fact there is a unconstrained clock is reported as below:
gxb_tx:gxb_tx_i|altera_xcvr_native_av:gxb_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts[0].gen_bonded_group_native.av_xcvr_native_inst|av_xcvr_avmm:inst_av_xcvr_avmm|avmm_interface_insts[0].av_hssi_avmm_interface_inst~BURIED_ASYNC_DATA_OUT
I don’t how to fix it due to it is a signal deep inside the DP IP.- Do you have a chance to try other refresh rate between 60Hz to 120Hz to see if it works ? Like eg : 75Hz ? I have try to lower the clock rate to 277.272MHz so the refresh rate changes to 112Hz. The result is the same.
- Question 5, please refer to question 4.
- I don’t have DP Aux transaction decoder equipment. Is there other way to do the debug in command shell?
Adam
