AdamKao's avatar
AdamKao
6 years ago
DisplayPort MST Failure
Hi Deshi,
The design works fine outputting DisplayPort video in MST mode and the stream count is set to 2 at 1920x1080p @ 60Hz output, but it only works on one channel when the refresh rate is increased to 120Hz.(297MHz pixel clock)
I have lowered frequency to 277272(277.272MHz) but the result is the same.
Adam
  • Deshi_Intel's avatar
    Deshi_Intel
    HI Adam,
    Understood that you could be busy with other higher priority project.
    This is fine but I also wanted to let you know I can't let the case idle for too long without any activity update.
    Therefore, I will proceed to close this existing case first.
    Feel free to post new forum thread when you are free to resume the debug discussion again then Intel agent will continue to support you.
    dlim
    Deshi_Intel
    Hi Adam,
    I have not hear back from you for few weeks.
    Any update from your side.
    dlim
    Deshi_Intel
    Hi Adam,
    Sorry for the late respond as I miss out your feedback in early Aug.
    Thanks for the clarification on SST vs MST log is due to different monitor.
    • In this case, I would categorize them as different hardware setup as the transceiver channel performance on SST monitor maybe difference than MST monitor
    Is your MST monitor = Asus PQ321Q ?
    • One thing that I want to clarify with you is you are not using typical MST test setup where we are either using MST hub or MST daisy chain monitor
    • So, I am not sure exactly how your MST monitor works
    • Would you be able to perform MST daisy chain monitor testing at your side ?
    As for the Aux log debug,
    • You can enable Aug log traffic monitor via BITEC_AUX_DEBUG parameter in Bitec software config.h. But we typically do this for Intel FPGA DP RX, I am not sure whether we can do it for DP Tx as in your use case or not
      • Assume it works, then you just need to open NIOS II shell while programming DP design into FPGA then it will auto capture all the AUX log traffic in NIOS II shell terminal
      • Then you can help me to capture the raw Aux log for both SST and MST monitor
      • The challenging part will be hard to decode the raw Aux log
    • Assume we are dealing with signal integrity issue here, easiest way will be to try out different brand DP cable, preferable shorter cable to improve the signal quality.
    dlim
    • AdamKao's avatar
      AdamKao
      Cyclone 10 GX
      Thank you.
      Adam
        Deshi_Intel
        Hi Adam,
        I have taken over this case back
        It's good to finally able to communicate with you directly without going through the dFAE.
        There are few questions that I would like to clarify with you.
        1. All the while we are taking about Arria V FPGA, your design files that DFAE shared with me earlier is also Arria V. Just curious why you suddenly mention about Cyclone 10 GX FPGA ? Can you clarify again which FPGA that you are using in your project development ?
        Below is also some follow up questions from my previous enquiry that I didn't hear back from you yet.
        1. You shared with us 2 MSA log file before (MSA_SST.txt and MSA_MST.txt)
          • SST naming is confusing as I still can see 2 stream result in the MSA log.
          • Can you clarify is this just file naming error ? Where both are actually MST design MSA log ?
          • Something like MSA_SST.txt = MST@60Hz, MSA_MST.txt = MST@120Hz ?
        2. Have you reviewed you MST stream 0 and stream 1 design to ensure there is no design difference particularly on the clocking side ?
        3. Also does your MST design meet Quartus Timequest design timing closure with positive margin slack ? Is your stream clock frequency correct ?
        4. Do you have a chance to try other refresh rate between 60Hz to 120Hz to see if it works ? Like eg : 75Hz ?
        5. For the btc_dptxll_stream_set_pixel_rate = 297000. It's meant for 2200 x 1125 x 120Hz. 277272 setting is meant for lower refresh rate. Just to confirm you are not running 120Hz refresh rate with 277272, right ?
        6. From the earlier MSA log, I can see DisplayPort link training failed and DP data rate reduced from 5.4G to 2.7G. Do you have DP Aux transaction decoder equipment like Unigraf DPA-400 to decode Aux log transaction to help us understand and isolate what's the issue with the "bad DisplayPort link training process"
        Deshi
