AdamKao
6 years agoDisplayPort MST Failure
Hi Deshi,
The design works fine outputting DisplayPort video in MST mode and the stream count is set to 2 at 1920x1080p @ 60Hz output, but it only works on one channel when the refresh rate is incr...
Deshi_Intel
6 years agoHI Adam,
Understood that you could be busy with other higher priority project.
This is fine but I also wanted to let you know I can't let the case idle for too long without any activity update.
Therefore, I will proceed to close this existing case first.
Feel free to post new forum thread when you are free to resume the debug discussion again then Intel agent will continue to support you.
dlim
