11 years agoDisabling PLL for Cyclone III
I am working to design a Cyclone III FPGA powered off of a 1.5 V battery. As I research powering all different parts of the FPGA, it looks like most output/input buffers etc. are receptive to this lo...
11 years agoI'm not aware of any, no.
However, all is not lost. I suggest you look at a charge pump to generate VCCA - you won't need much current. You need to regulate down to 1.2V for VCCINT. Maxim do a max1682 (http://www.maximintegrated.com/en/products/power/charge-pumps/max1682.html) voltage doubler intended for battery driven appliances. Put your newly regulated 1.2V rail into it and you'll have something in spec... Cheers, Alex
