8 years agoDisable Device ID check during JTAG Programming
Hello Community, Altera, Intel, sorry for multiple posts, but i would like to seperate discussions about 125°C Flash Memory. I would like to use a 125° Automotive configuration flash IC (...
8 years ago --- Quote Start --- I had room on the board for the huge EPCQ part, so I just used it. --- Quote End --- That was also my approach in case of EPCQ256, to be on the safe side and have the Altera device as an assembly option, also in case of a supply bottleneck. But I found out that Micron N25Q256A13ESF worked as perfect replacement. I guess that newer Micron MT25Q256 will work as well, but didn't yet check.
