8 years agoDisable Device ID check during JTAG Programming
Hello Community, Altera, Intel, sorry for multiple posts, but i would like to seperate discussions about 125°C Flash Memory. I would like to use a 125° Automotive configuration flash IC (...
8 years ago --- Quote Start --- Which error do you actually see? Wrong device ID in Quartus programmer? --- Quote End --- Oh, yes, the typical error message: Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly. Error (209012): Operation failed --- Quote Start --- There would be still the option to write the AS flash by custom logic or external hardware. --- Quote End --- Yes, but i would have spend ages for a custom external programmer only to avoid this "artifical software problem". (Maybe it would be easier to switch to an other FPGA brand. But i assume every manufacturer has it's own problems.) Or is there a easy "external hardware" solution? Indeed, i have my own CAN-Bootloader - but this is so slow and i always need a running Microcontroller and CAn Controller and CAN-Bootloader software. No way for fast development.
