12 years agoDigital audio player, help choosing the right device
I'm not sure this is the right forum section to post the new thread. I'm new in FPGA design, so I need some suggestions to choise the right device. I would build a digital audio player with t...
12 years ago --- Quote Start --- Ehm, it's kinda awkward to say this on an Altera forum, but it doesn't look like you need an FPGA here. Reading a FAT filesystem means that you probably need a decent processor (most likely some ARM, but there are other around). Audio is something commonly supported. You can, of course, do this with an FPGA or a SoC device, but it's a heavy overkill, and odds are that a plain processor device will be the most cost-effective. Cheers, Andrew --- Quote End --- Sorry for my ignorance, do you think I can use also a Cyclone V SE with ARM embedded? Or a Cyclone V GX with Nios processor? There are 2 examples in the evaluation board user manual (C5G_User_Manual.pdf from Terasic): - 6.6 Micro SD Card file system read - 6.7 SD Card music player demonstration Andrea
