12 years agoDifficulty reading into FPGA SDRAM from HPS
I am running a slightly modified version of GHRD from rocketboards on my Cyclone V Dev Kit. Right now I am having difficulty trying to read from FPGA SDRAM in Linux, which I connected to H2F bridge. The strange thing is, I can write to it, but when I try to read, it just hanged. I am quite new in FPGA, if anyone has experienced the same thing, or has any clue to what have caused this, I appreciate if you could help me. This is how I connected the SDRAM controller: https://www.dropbox.com/s/o3snhlg0r1cnchd/fpga.png and settings: https://www.dropbox.com/s/e6vuxqwim0cczvw/configsdram.png Thanks.2 Replies
After debugging with SignalTap, it seems that my local_cal_fail is asserted high, and local_init_done is low..
What can cause this? - Altera_Forum
I solved this, the reason is timing error (slack too much) :
1. Use afi_clk to drive both h2f axi master and the fifos 2. Use higher frequency on fpga_clk_50 to 125mhz
