SWilb1's avatar
SWilb1
7 years ago
Difference between 5ceFa and 5ceBa
If my design takes Cyclone V E 5cefa, but doesn't use hard memory controllers, is it interchangeable with the 5ceba of the same die and package size?
  • SWilb1's avatar
    SWilb1
    Thank you, Anand,
    I did check pin-for-pin between the two devices I am evaluating. The primary use pins are identical between the "F" and "B" versions. The "F" version has some pins with secondary use for HMC, but since all these pins have primary use as I/Os, I conclude the two versions with same die size and package are interchangeable (absent HMC use).
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Yes, You can migrate to 5CEBA if device densities in the same package option if the devices have the same dedicated pins, configuration pins, and power pins.
    Compare the pinout files.
    And check page 18/ figure 17 from below link.
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51001.pdf
    Anand
