8 years agoDifference between 128 bit 250 MHz and 256 bit 125 MHz
Hi, I have a PCIe in Gen3 x4 mode configured as a root port. I have 2 options for Gen3 x4. 128 bit 250 MHz or 256 bit 125 MHz. What is the difference between the two? I have looked into ...
8 years agoThis should be more a question of what do you need. Faster clock will be harder to place and route, but the wide bus will likely need more resources in your processing pipeline.
