16 years agodev/uart_rs232
Hello! I try to send data to the rs232 of the Nios Embedded Evaluation kit. I used the SOPC Builder and used the SOPC files of the Nios II System Architect Design Tutorial. There I put in ...
16 years agoI think that if you use a component as stdout, it isn't available for access through fopen() anymore.
If you put stdout to the UART, then you can directly call printf() without opening any file, and the output should go to the UART.
