16 years agodev/uart_rs232
Hello! I try to send data to the rs232 of the Nios Embedded Evaluation kit. I used the SOPC Builder and used the SOPC files of the Nios II System Architect Design Tutorial. There I put in ...
16 years agoAfter puting the Pins txd and rxd to e18 and h17,
I did Assignments-> Device-> Device and Pin Options-> Dual Purpose Pins-> all use as regular IO except DCLK and ->Configuration scheme -> Active Parallel and -> configuration mode-> Remote. After compilation theere are always errors. Error: Configuration mode specified as Remote but remote update block is not found in design Info: Fitter preparation operations ending: elapsed time is 00:00:00 Warning: Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Error: Can't fit design in device Error: Quartus II Fitter was unsuccessful. 2 errors, 2 warnings Error: Peak virtual memory: 250 megabytes Error: Processing ended: Tue Oct 05 12:37:17 2010 Error: Elapsed time: 00:00:10 Error: Total CPU time (on all processors): 00:00:10 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 276 warnings
