16 years agodev/uart_rs232
Hello! I try to send data to the rs232 of the Nios Embedded Evaluation kit. I used the SOPC Builder and used the SOPC files of the Nios II System Architect Design Tutorial. There I put in ...
16 years agoThanks for reply Ealonso!
I solved the problem last night at 11 pm. i did the same like you said. The problem was that the pins have different names from one side to the other. The HSMC_TX_p11 (pin 119 and named uart_txd on lcd daughtercard) is the pin that goes to H17 of Bank 6. The HSMC_TX_n10 (pin 115 and named uart_rxd on lcd daughtercard) is the pin that goes to E18 of Bank 6. Why so uncomfartable? Who needs the finished sopc file and the fpga can weite me.
