15 years ago
Devide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare.
When I try with "*" (multiply) or "+" (add), it is ok.
I don't know this error, Please help me.
Thank you very much.
    When I use Modelsim to simulate VHDL code, It show an error with LPM library?
    I want to use devide command with lpm library, what should I do?
    Thank you very much. I had finish my exercise. I used lpm_devide.
    "/" for integers is not part of std_logic_arith, it is part of the standar library.
    --- Quote Start ---
    The Std_logic_arith library does not have a divide function.
    --- Quote End ---
    It has, but only for integer data type. numeric_std supports inference of divider MegaFunction for signed and unsigned data types.
    The Std_logic_arith library does not have a divide function. The numeric_std library has a divide function, so try that instead.
    BUT - Divide is very resource intensive, and doing it in 1 clock cycle will cause the FMax to drop. Use the lpm_divide megafunction instead.
