15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years ago --- Quote Start --- You can precompile most libraries in Modelsim. Usually altera_modelsim will have these lpm/altera_mf libraries ready from installation. Otherwise you can precompile as follows: go to modelsim => compile => set library name to lpm => navigate to altera folders that contain 220pack.vhd/220model.vhd. select them and compile. --- Quote End --- I don't know, why menu compile of my Modelsim software is not active. I can not choose it. I add 220pack.vhd/220model.vhd to my project and compile => not ok I can not make new library from "a new library and a logical mapping to it" or "a map to an existing library" to folder that contain 220pack.vhd/220model.vhd file. This is my video: Add 220pack.vhd/220model.vhd to project and compile them: http://www.mediafire.com/?44i1sj5bgnkduty Can not make new library: http://www.mediafire.com/?53zp5xyrpd2zdjk Can not make new library: http://www.mediafire.com/?krc4l1g5u5uyayj Could you check it for me. Thank alot
