15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years ago --- Quote Start --- You can precompile most libraries in Modelsim. Usually altera_modelsim will have these lpm/altera_mf libraries ready from installation. Otherwise you can precompile as follows: go to modelsim => compile => set library name to lpm => navigate to altera folders that contain 220pack.vhd/220model.vhd. select them and compile. --- Quote End --- Thank Kaz I had done that a lot of time but it still error (Modelsim said, they do not found lpm library). I will make it step by step and send it to you, i hope you check it for me. Thanks again
