11 years agoDevice problem(EP4CGX150DF27I7)
hi:
I have buy some fpga devices , EP4CGX150DF27I7,the silkscreen of device surface as the following imae. I can`t understand the silkcreen represent what mean? or the devices are bad?5 Replies
--- Quote Start --- hi: I have buy some fpga devices , EP4CGX150DF27I7,the silkscreen of device surface as the following imae. I can`t understand the silkcreen represent what mean? or the devices are bad? --- Quote End --- That is a larger member of the cyclone 4 family of devices. As long as the parts are real, and not fake, they are good parts: http://www.buyaltera.com/scripts/partsearch.dll?detail&name=ep4cgx150df27i7-nd https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-51001.pdf Pete - Altera_Forum
Any issues when mounted on board? As mentioned by anakha, that seems legit. (http://www.buyaltera.com/scripts/partsearch.dll?detail&name=ep4cgx150df27i7-nd)
Seems like no anomaly with the part. It is recommended to try with actual board. You may try using the JTAG to detect the device to verify if it is the 150 part that you want.
You can verifying the device functionality by mounting it on board. If any issue observed, you may contact the supplier that you purchase from for further assistance.
U can check the top marking format from this Altera KDB solution's link https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10292013_192.html
But i guess u dont have to worry too much if u bought them from an authorized distributor.
