Aaron
10 months agoDevice migration about DD and DA
Hi Sir, 10M50DDF256C8G vs 10M50DAF256C8G My understanding is that the DD and DA packages are the same, or at least pin-to-pin compatible. However, when I tried using Quartus, I found that Device Mi...
Aaron
9 months agoHi Aqid,
I used 25.1standard.
as you mention you agree withboth OPN should be compatible with each other. Since the difference is only in the flash access control feature.
Future will modify at Quartus?
And can I confim to customer both OPN compatible with each other?
Aaron Hsu
AqidAyman_Altera
9 months agoHi Aaron,
I also got confirmation internally that only vertical migrations are supported through Quartus GUI (Migratable devices are listed in the "Migration Devices" window).
Conditional Migration requires PCB design considerations and is not supported in Quartus software.
Aqid
