Device migration about DD and DA
Hello Aaron,
Can you share which Quartus version are you using?
Let me check internally on this.
Aqid
Hi Aqid,
I used 25.1standard.
as you mention you agree withboth OPN should be compatible with each other. Since the difference is only in the flash access control feature.
Future will modify at Quartus?
And can I confim to customer both OPN compatible with each other?
Aaron Hsu
- AqidAyman_Altera9 months ago
Hi Aaron,
I also got confirmation internally that only vertical migrations are supported through Quartus GUI (Migratable devices are listed in the "Migration Devices" window).
Conditional Migration requires PCB design considerations and is not supported in Quartus software.
Aqid - AqidAyman_Altera9 months ago
Hi Aaron,
The Device Migration window in Quartus is only applicable for vertical migration. Since this device has a difference in features, it depends on the design if you want to do a direct migration.
In other words, in terms of pinout, it is migratable. However, for design, it depends.
Aqid
