Aaron
10 months agoDevice migration about DD and DA
Hi Sir, 10M50DDF256C8G vs 10M50DAF256C8G My understanding is that the DD and DA packages are the same, or at least pin-to-pin compatible. However, when I tried using Quartus, I found that Device Mi...
AqidAyman_Altera
10 months agoHello Aaron,
Can you share which Quartus version are you using?
Let me check internally on this.
Aqid
FvM
10 months agoHi Aqid,
no migration compatbility between 10M50DDF256C8G and 10M50DAF256C8G, neither in Quartus Prime 24.1 Std nor 25.1 Std.
Frank
- AqidAyman_Altera10 months ago
Hi Frank,
Yeah, I checked and verified that.
However, I do agree with you that both OPN should be compatible with each other. Since the difference is only in the flash access control feature.
Aqid
