11 years agoDetection problem in JTAG with MAX7000S
Hello, i'm newbie with FPGAs programming. I'm trying to use JTAG on a Max7000S (exactly an EPM7160STI100), without satisfying results. When i try "Auto Detect" fonction i have this message "Una...
11 years agoTry removing the pull-up resistor from TDO (it shouldn't need it anyway).
900 ohms is too low for my liking. Refer to the 'pull-up and pull-down of jtag pins during in-system programming' section of an-100 (http://www.altera.com/literature/an/an100.pdf) for guidance. If it's the only device in your JTAG chain you shouldn't need any pull up/down resistors. Cheers, Alex
