11 years agoDetection problem in JTAG with MAX7000S
Hello, i'm newbie with FPGAs programming. I'm trying to use JTAG on a Max7000S (exactly an EPM7160STI100), without satisfying results.
When i try "Auto Detect" fonction i have this message "Unable to scan device chain. Can't scan devie chain". So, i try the JTAG Chain Debugger,"Test JTAG chain" and... JTAG chain problem detected No device detected The TDO connection to the download cable might be shorted to VCC or is an open circuit The TCK and TMS connections to the last device might have problem When i look TCK, TMS, TDO and TDI on scope, i have some correct signals on TCK, TMS and TDI, but only 5V constant on TDO, is it normal? I have a pull down for TCK, three pull up for TMS, TDI and TDO. Resistors of 900ohm. If you have proposition, i take it !1 Reply
Try removing the pull-up resistor from TDO (it shouldn't need it anyway).
900 ohms is too low for my liking. Refer to the 'pull-up and pull-down of jtag pins during in-system programming' section of an-100 (http://www.altera.com/literature/an/an100.pdf) for guidance. If it's the only device in your JTAG chain you shouldn't need any pull up/down resistors. Cheers, Alex
