16 years ago
detect video Signal
hello, could someone explain me this following code? i have found it in a demo application but with no Comments. thank you
module sigdetect(
oTD_Stable,
iTD_VS,
iTD_HS,
iRST_N );
input iTD_VS;
input iTD_HS;
input iRST_N;
output oTD_Stable;
reg TD_Stable;
reg Pre_VS;
reg [7:0] Stable_Cont;
assign oTD_Stable = TD_Stable;
always@(posedge iTD_HS or negedge iRST_N)
begin
if(!iRST_N)
begin
TD_Stable <= 1'b0;
Stable_Cont <= 4'h0;
Pre_VS <= 1'b0;
end
else
begin
Pre_VS <= iTD_VS;
if(!iTD_VS)
Stable_Cont <= Stable_Cont+1'b1;
else
Stable_Cont <= 0;
if({Pre_VS,iTD_VS}==2'b01)
begin
if(Stable_Cont==9)
TD_Stable <= 1'b1;
else
TD_Stable <= 1'b0;
end
end
end
    --- Quote Start ---
    i cannot find this info that the V-blank is 9 horizontal sync pulses, can you give me more details...thanks
    --- Quote End ---
    It's depend on video signal. Different video signal have different parameter. The exactly 9 pulses looks very strange. Usually for video signal specified duration of V-blank, H-blank. And not exactly. You can find parameters for PAL or SECAM or VGA.
    --- Quote Start ---
    It's you video signal parameter. You V-blank duration is 9 horizontal sync pulses.
    --- Quote End ---
    --- Quote Start ---
    thank you for your Answer, aber i can't understand why 9 pulse is using
    --- Quote End ---
    --- Quote Start ---
    module sigdetect(
    oTD_Stable,
    iTD_VS,
    iTD_HS,
    iRST_N );
    input iTD_VS;
    input iTD_HS;
    input iRST_N;
    output oTD_Stable;
    reg TD_Stable;
    reg Pre_VS;
    begin
    if(!iRST_N)
    begin
    TD_Stable <= 1'b0;
    Pre_VS <= 1'b0;
    end
    else
    begin
    Pre_VS <= iTD_VS;
    if(!iTD_VS)
    else
    Stable_Cont <= 0;
    begin
    if(Stable_Cont==9)
    TD_Stable <= 1'b1;
    else
    TD_Stable <= 1'b0;
    end
    end
    end
    --- Quote End ---
    module sigdetect (oTD_Stable, iTD_VS, iTD_HS, iRST_N);
    input iTD_VS;
    input iTD_HS;
    input iRST_N;
    output oTD_Stable;
    reg TD_Stable;
    reg Pre_VS;
    reg Stable_Cont;
    always @ (posedge iTD_HS or negedge iRST_N)
      begin if (!iRST_N)
        begin //all reset
        TD_Stable <= 1 'b0;
        Stable_Cont <= 4' h0;
        Pre_VS <= 1 'b0;
        end
      else
       begin //this is for each horisontal syno impulse
         Pre_VS <= iTD_VS;
         if(!iTD_VS)Stable_Cont <= Stable_Cont+1' b1; // blank time. Old frame is finish. But new frame is not begun. count HS singal pulses during blank time.
         else Stable_Cont <= 0;// draw frame. do nothing
         if ({Pre_VS, iTD_VS} == 2 'b01)// new frame is begin.
         begin
           if(Stable_Cont==9) TD_Stable <= 1' b1; // if during blank time been 9 pulses HS the signal is stable.
           else TD_Stable <= 1 'b0; // signal not stable.
         end
       end
    end
    blank time os "back moving beam". I don't know how to in english.
