11 years agodetect a signal was at 1
I would like to know if there is a simple block diagram function that can detect if a signal is or was at 1? So a block diagram that has an output signal that is always at 1 from the moment where there is a rising edge on a signal. Thanks2 Replies
You can also try the Dlatch primitive in the Quartus II.
an or gate with the output connected to one of it's input is the simplest latch. Would require a power cycle to reset.
