Design works in ASE not on FPGA
Our design works in the ASE simulation environment. But it doesn't work on FPGA. Timing constraints are being met.
Please let us know as to what we might be missing / going wrong.
Thanks for the response. The steps to run on FPGA seems to require using AFU, which unfortunately I don't have the resources to.
Is it possible to share a tar.gz file of the Quartus project?
Also, in a previous comment you mentioned you want to view waveform generated in real time on FPGA, you can use Signal Tap Logic Analyzer: https://www.intel.com/content/www/us/en/docs/programmable/683819/21-3/logic-analyzer-introduction.html
If you want to do RTL simulation you can do so as well, here's an example: https://www.intel.com/content/www/us/en/docs/programmable/683870/22-1/quick-start-example-modelsim-with-verilog.html
Nurina
- Navaneeth
We haven't received any such errors. The ccip_std_afu is located in the hw/rtl/ccip_std_afu.sv file.
We're using the streaming-dma-afu BBB as our base design and we've included our files - split.sv and cmm_top.sv ( our matrix multiplier verilog code file ) - in hw/rtl/QSYS_IPS/avst_decimator folder. - Nurina
I've included the modules in hw/rtl/ but I still see some errors related to it.
Error(13406): Verilog HDL error at afu.sv(31): object "ccip_avmm_pkg" is not declared
Error(13406): Verilog HDL error at afu.sv(139): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(139): range must be bounded by constant expressions
Error(14395): Verilog HDL error at afu.sv(140): CCIP_AVMM_REQUESTOR_WR_ADDR_WIDTH is not a constant
Error(17457): Verilog HDL error at afu.sv(140): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(142): object "CCIP_AVMM_REQUESTOR_BURST_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(142): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(147): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(147): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(149): object "CCIP_AVMM_REQUESTOR_DATA_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(149): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(150): object "CCIP_AVMM_REQUESTOR_RD_ADDR_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(150): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(153): object "CCIP_AVMM_REQUESTOR_BURST_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(153): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(156): object "CCIP_AVMM_MMIO_DATA_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(156): range must be bounded by constant expressions
Error(13406): Verilog HDL error at afu.sv(158): object "CCIP_AVMM_MMIO_DATA_WIDTH" is not declared
Error(17457): Verilog HDL error at afu.sv(158): range must be bounded by constant expressions
Error(16827): Verilog HDL error at ccip_std_afu.sv(34): cannot open include file cci_mpf_if.vh
Error(13406): Verilog HDL error at ccip_std_afu.sv(35): object "cci_mpf_csrs_pkg" is not declared
Received this critical warning:
Critical Warning(125091): Tcl error: couldn't read file "../../hw/rtl/BBB_ccip_avmm/hw/par/ccip_avmm_addenda.qsf": no such file or directory while executing "source ../../hw/rtl/BBB_ccip_avmm/hw/par/ccip_avmm_addenda.qsf" (file "../hw/afu.qsf" line 6)
The project I received doesn't have the folder ../../hw/rtl/BBB_ccip_avmm/hw/par/
Is this required in the project?
Nurina
- Navaneeth
Sorry for the delayed response.
Can you please try with https://drive.google.com/file/d/1K9rg_u6i57mGkBegACfYQz5UjMJiNV8N/view?usp=share_link?
Steps to run ASE ( after extracting the tar.gz file
1. cd Capstone-Streaming-DMA-AFU
2. afu_sim_setup --source=./hw/rtl/filelist.txt build_ase_dir
3. cd build_ase_dir
4. make -j16 ( takes around 5 minutes )
5. two screen sessions are needed
On first:
1. make sim -j16
2. < copy the export path >
On second:
1. cd sw
2. < paste the export path >
3. make USE_ASE=1
4. ./fpga_dma_st_test -l on -s 2048 -p 64 -t fixed -f 0
Steps to run on FPGA:
2. afu_synth_setup --source=./hw/rtl/filelist.txt build_synth_dir
3. cp afu_default.qsf build_synth_dir/build/
4. cp flame-job-script.sh build_synth_dir
5. cd build_synth_dir
6. ./flame-job-script.sh ( takes around 2 hours )
7. fpgaconf streaming_dma_afu.gbs
8. cd ../sw
9. make
10. ./fpga_dma_st_test -l on -s 2048 -p 64 -t fixed -f 0
Navaneeth M - Nurina
May I know if you have any updates?
Nurina
- Navaneeth
We realised that the FIFO IP was not working when we run on the FPGA.
So, we used our queues and now we're able to get the results on FPGA.
Navaneeth M
- Nurina
We do not receive any response from you on the previous reply provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
