17 years ago
DESign.sof
Hello!
I have a little problem whit a design file, i have a Stratix II board model: EP2S60F672C3 and when i open my design file DESign.sof whit the Programmer in Quartus II i see the file whit other device: EP20K200EF484.
Error: Can't configure device. Expected JTAG ID code 0x082000DD for device 1, but found JTAG ID code 0x120930DD.
Error: Operation failed.
These are the errors i get when i try to start this file...
Id like to know how could i change the device for that file to make that file for my device...
I will apreciate youre help and assitance.
Thank you!
    For Altera 8B/10B encoder IP core you need to purchase a separate license to use it in your application. It's available for free OpenCore Plus Evaluation as described in the user guide. You can also find free 8B/10B cores at opencores.org.
    I saw Quartus have ed8b10b encoder/decoder, anyone can help me whit this? how to? i have read and follow the steps in /ug-ed8b10b.pdf literature but i have problems loading the libraries. Is there anyone to have this encoder/decoder available? Mail it? :) please.
    --- Quote Start ---
    Pletz
    Nois or Nios? You mean Nios II processor? id like to learn making one... :)
    --- Quote End ---
    Yes, I mean the the Nios II processor. It lookslike that he is used in the tutorial. Is there no description in the tutorial how to generate the Nios II ? I would expect that the required design files are somewhere in the tutorial database.
    Pletz
    --- Quote Start ---
    Hello Pletz!
    Well i didnt generated this file, i have downloaded it from a website. Is there a way i can convert this file to fit on my board? I have started to read on altera website help and learning but it looks like im far away from my interests. The file is part of a des key extractor.
    Hello Parrado!
    I have tryed manny times i have started to read on altera website help and documentation regarding Quartus II software and found this, so i have tryed i selected my device but compilation was unsuccessfull all the times manny errors.
    I uploaded the files in discussion now so maybe i can get better help.
    I also look on altera video demos on compiling programming and i started learning but at the moment i am in the very beginning phase... from what i understood is that i can design almost any kind of electronics so i have more questions regarding this board... is it posible to use it as a LAN card to my computer? Video card?
    Thank you all for youre respnoses!
    --- Quote End ---
    I have setup a project for you. Unfortunately the design files are not complete. The Nois is missing, but maybe you can use the project as starting point.
    A FPGA configuration file can't be converted to another device type, it has to be generated from the original project files. The appended files however aren't a complete project.
    Hello Pletz!
    Hello Parrado!
    In menu:
    assignments->device
    choose your Stratix II device.
    and Compile again.
    --- Quote Start ---
    Hello!
    Thank you!
    --- Quote End ---
    how do you generate the design.sof file ?
