Design a BCD counter with a asynchronous master reset. Display the values 0 to 9 on
Design a BCD counter with a asynchronous master reset. Display the values 0 to 9 on the 7-segment display and whenever the count is 1, 3 or 5, a Led will turn on.
HI,i have a problem with the program with regards to the led_on.Can any kind soul provides some advice on this? This is so far what i've done, -- a BCD coubter with asynchronous reset library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity bcd_counter is port ( clk, reset_bar,led_on: in std_logic; q : out std_logic_vector (9 downto 0)); end bcd_counter; architecture flow of bcd_counter is signal count_sig: unsigned (9 downto 0); begin process (clk, reset_bar,led_on) begin if (reset_bar = '1' and led_on = '1') then count_sig <= "0000000000"; elsif falling_edge (clk) then if (count_sig = 9) then count_sig <= "0000000000"; else count_sig <= count_sig +1; if(led_on = '1') then count_sig <="0000000000"; else count_sig<= count_sig +1; end if; end if; end if; end process; q <= std_logic_vector (count_sig); end flow;7 Replies
A testbench is a peice of VHDL code used to drive your unit under test in a simulator, not the board you're going to run your design on.
Plz describe your needs for the programm.
Also describe what every input has to do. We can't figure out what the code has to do (or what u whant LED_ON has to do). - Altera_Forum
the resetbar is a master reset. Even with the compilation, the led_on was still unable to on. How do i use the if else, particularly on the led_on? So far what i've came out, is for the reset_bar. :
From the looks of it led_on is your reset signal, and reset_bar specifies if its an async or sync reset.
What does your testbench code look like? - Altera_Forum
counter_enable which triggers the 9 output. I tried compiling the graph, the only thing that doesn't toggles is the led_on ): Is it because theres a problem with my if, else? Or do i have to include the led_on, on a separate if,else statement? I really need help on this ):
What does LED_ON do ? Is it like : counter_enable?
Or do u whant to turn the led (make is light'n up)?
