15 years agoDesign a BCD counter with a asynchronous master reset. Display the values 0 to 9 on
Design a BCD counter with a asynchronous master reset. Display the values 0 to 9 on the 7-segment display and whenever the count is 1, 3 or 5, a Led will turn on. HI,i have a problem with the ...
15 years agoA testbench is a peice of VHDL code used to drive your unit under test in a simulator, not the board you're going to run your design on.
