Deserializers in Agilex 3 series
- 1 year ago
Agilex 3 lvds serdes only has x4 and x8 serdes factor. If you check datasheet and i screenshot the ip settings as below (had been confirmed among lvds team):
How does Altera suggest a 360Mhz, x10 bit deserialization factor, 5-Lane SerDes be implemented in the Agilex 3 device?
Do it with an x8 deserializer. Deserialize each lane by 8. Line rate = 360 MHz × 10 = 3.6 Gb/s (SDR). Line rate = 360 MHz × 10 = 3.6 Gb/s (SDR). Parallel rate after ÷8 = 3.6 Gb/s ÷ 8 = 450 MHz byte (8-bit) clock/domain. Feed the 360 MHz source-synchronous clock into an IOPLL and outputs with 360 MHz = your final 10-bit symbol clock (core domain) while 450 MHz = the x8 parallel domain for the SERDES output. Ratio is 450/360 = 1.25 (fractional PLL). Keep both clocks phase-related.
We have clock crossing adapter type to adapt the CDC https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/interconnect-requirements.html
I do not believe I understood your answer very clearly. Do you mean that the Agilex 3 device will not be able to implement the x10 deserialization factor?
Is the MiPi interface also limited to 8b deserialization?
UM
