18 years agoDeos the plls of a fpga exactly same?
Hi, I have questions about pll. 1. If I use one clock source(27MHz) driving two plls in one fpga, and the parameter of plls is the same(generate 135MHz, but phase is same or different), Can ...
18 years agoFvM,
Very interesting idea, but seems dangerous to use without confirmation from Altera this is by design and reliable. I think I will have to live without using the dedicated PLL output pins. Not that bad as long as I can constrain the routing delay. Is it possible to constrain the routing delay between the PLL output and a specific pin? The alternative would be to use back-annotated routing, but this is something I'd really like to avoid.
