18 years agoDeos the plls of a fpga exactly same?
Hi, I have questions about pll. 1. If I use one clock source(27MHz) driving two plls in one fpga, and the parameter of plls is the same(generate 135MHz, but phase is same or different), Can ...
18 years ago --- Quote Start --- If driving multiple PLLs with the same clock, you can't ever consider divided clocks as the same, as the PLLs may create them on different phases. (I can explain it if it doesn't make sense, and have a design to get around this issue.) --- Quote End --- Would you mind elaborating on this? Is it possible to phase align the output of two different PLLs driven by the same clock, when using division?
