14 years agoDemux output behavior
I have a question on a demux, says 1:2 demux, and let's call A and B are the output. Then the input is connected to A, then what is the value of B? Is B holding the previous value? or unpredictable? My simple code for the demux is: --------------------------------------- library ieee; use ieee.std_logic_1164.all; entity sample_demux is port( in, clk, sel: in std_logic; out1, out2: out std_logic ); end sample_demux; architecture rtl of sample_demux is begin process(clk) begin if clk'event and clk='1' then case sel is when '0' => out1 <= in; when '1' => out2 <= in; end case; end if; end process; end rtl; ---------------------------- Actually, I want to keep the previous value even when the output is not connected to the input. Thanks!2 Replies
Thanks a lot!
--- Quote Start --- Your code will hold the previous output in B --- Quote End --- - Altera_Forum
