14 years agoDefault Value for Bidirectional differential signal
Hey everyone, I am creating a parametrized project which synthesizes a DDR2 controller only when the user specifies it is needed via a generate statement. There are 2 differential clock pins wh...
14 years agoI am a bit unsure what actually you want or why. Unused pins (all) have options such as (as inputs tristated, ...etc) and you can choose whichever. But it has to be unused, so no logic connected to it.
If you want unused pins to be other than that but you only want those pins to be tristated then you can apply 'Z' permanently. If you want to keep it bidirectional and I don't see why you can use a dummy select input for output enable, I mean use an unused input to do that selection and fool the tool
