11 years agoDedicated Clock Input Pins in Arria V
Good day. There is one question about “dedicated clock pins CLK[23..0]p,n”. In pin connection guidelines it is stated that these pins are dedicated positive and negative clock input pins, that ca...
11 years agoHi, the dedicated clock pins can be used for data input pins for differential I/O standard. When you use the single-ended I/O standard, only the CLK[0:23]p pins serve as the dedicated input pins to the PLL
You can refer to the pin connection guidelines for more details about this CLK[0:23][p:n] https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/pcg-01013.pdf
