Isaacs
5 years agoDECA Board: PLL frequency signal distortion for MHz frequencies
I'm working with the DECA board, I'm using the Basic Function to generate a PLL with the ALTPLL tool. Everything works fine with lower frequency from 1kHz-1MHz, the problem stars when I'm t...
Ash_R_Altera
4 years agoPutting my thought anyway.
What compensation mode did you use?
Check if you are driving the PLL output clock to a FPGA pin which is creating some contention on board? Try assigning to other pin.
Check the clock internally using Signal Tap Analyzer.
