9 years agoDebugging active serial programming issue
I have strange issue: Cyclone 3 device with EPCS16 was programming properly before, now programmer says "can not recognize silicon ID". Programming device was replaced (USB blaster - ByteBlaste...
9 years ago --- Quote Start --- In AS programming, the FPGA is not shut down, just the FPGA AS-interface tri-stated by driving nCE high. --- Quote End --- Thank you. I did not investigate how it works exactly, probably that's why I ask this question. --- Quote Start --- If you have also a FPGA JTAG interface available, you can try to write the flash through JTAG indirect programming instead. --- Quote End --- I do not think so. It is connected using AS circuitry, there's place for JTAG connector, but it is not soldered in. --- Quote Start --- If you say, AS programming has worked before, what did you exactly change? PC software (e.g. JTAG drivers), board and programming hardware can matter. --- Quote End --- This is actually very good question. I have this issue remotely (not in my location), software is compatible Quartus 13.0.1 supporting the Cyclone 3. Interesting that same software with same blaster and even cable seem to work well on CPLD, but my guess that CPLD does not use active serial, that's why I ask for information where to dig (e.g. check some wire connectivity etc) - whatever which can shed light onto the issue. Edit: I have same programming device here, with same Quartus version, and it works. So I guess there should be really something wrong there.
