17 years ago
DE3 THDB-ADA problem
Dear guys,
I am having a trouble with the Terasic DE3 THDB-ADA board.
First I tried to run the demo on the CD. After compilation, when I
programed the device, I got this message: File
G:/TERASIC_ADA/Demostrations/DE3_ADA/150ES/DE3_time_limited.sof contains
one or more time-limited megafunctions that support the OpenCore plus
feature that will not work after the hardware evaluation time expires.
So I tested the D/A with a small VHDL file. I connected the ADA to the
HSTC_D on the DE3 board. I found the pin assignment for the D/A in the
demo file. I tried to output a sin wave. But nothing was
shown even I just sent a constant number to D/A.
I saw a component IOV_A3v3_b3v3_c3v3_d3v3 in the demo, what is it
for?
My VHDL code is attached.
Thanks for helping!
    60 Hz is attenuated to effectively zero. There is an option to desolder the transformer and place a jumper resistor. Then you get a DC capable single ended DAC outputs.
    No, I didn't know about that. Does that mean that I can't output a sine wave of less than 400kHz?? What about 60Hz.?
    Did you notice that the ADA board has a transformer coupled DA output? It has a lower cut-off frequency of 0.4 MHz and surely can't transmit DC levels. If you apply sine or other generated signals, they should have a sufficient frequency.
