17 years ago
DE2_TV searching XY coordinates of pixels
Hi @all,
I am currently working with the DE2 Dev.&Edu. Board with Cyclone II.
In my project I am supposed to do a simple blob detection. The blobs are represented by white dots on black background.
Since I am new I decided to start with the DE2_TV example to become familiar with the dataflow. If I did understand it correct the program does the manipulation of the data pixel-wise, which means that the information which pixel it is actually manipulating should be available.
But I am a little bit confused which register does hold the information.
I thought it should be the ports oCurrent_X and oCurrent_Y from the VGA_Ctrl module, but if thats the case why is the register 11 bit.
This would allow a resolution of 2048x2048 (I know this is not the correct relation, it's just a example).
But the output of the VGA has only a resolution of 640 x 480, so the coordinates of X and Y should be lay inbetween.
Can someone help me here?
Where can I get the X and Y coordinates for the pixels?
regards,
Alex
