17 years agoDE2_TV searching XY coordinates of pixels
Hi @all, I am currently working with the DE2 Dev.&Edu. Board with Cyclone II. In my project I am supposed to do a simple blob detection. The blobs are represented by white dots on black backg...
16 years agoHi,
sry for the late reply. I am busy working on a project. I have attached for you the whole project folder, which is basically the manipulated version of the DE2 demonstration. The interesting module for you should be run_line_detection.sv There I do a pixel-wise detection of binary large objects in a frame. The beginning of a frame is identified by the pixel coordinates. I think if you just delete most of the source an do the flipping of the pixel-values, then you are done. The source is very bad because I am still working on it. Just ask if something is unclear. regards, Alex
