18 years ago
DE2 Quartus debounced circuit
I am working on a senior design project and have a DE2 board connected to external circuitry. There are pushbuttons on the external circuit which control leds also on that circuit board. My design requires that I press the pushbutton and the led lights up and I press it a second time and the led goes off.
It turns out that those pushbuttons which are single-pole-double-throw (SPDT) are not debounced and give multiple outputs when I want a clean signal.
I would like to know if there is a reference design so I can build debounced circuitry for the buttons in Quartus. If not, how do I build debouncers in Quartus for SPDT pushbuttons?
Kofi.
    I made a simplest program for hex counter it supposed to count push-button clicks.
    It present the result on a single 7seg display and 4 LEDs, unfortunately I've got a bouncing problem.
    I'm using a Altera Cyclone II BAIXUN ASK2CB dev. board it has on board push-button
    Can you please suggest how can i debounce it, so the bits go one by one?
    Here is my code:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    entity test is
    port (Y : out std_logic_vector (6 downto 0); -- 7 seg digit
    B : out std_logic;
    pb : in std_logic;
    count : out std_logic_vector(3 downto 0);
    reset :in std_logic
    end entity test;
    architecture Behavioral of test is
    signal c: std_logic_vector(3 downto 0) :=(others => '0'); --initializing count to zero.
    begin
    counting: process(pb,reset) is
    begin
    if rising_edge (pb) then
    if(c = "1111") then -- when count reaches its maximum(that is 15) reset it to 0
    c <="0000";
    end if;
    c <= c+'1'; --increment count at every positive edge of clk.
    end if;
    if(reset='0') then --when reset equal to '0' make count equal to 0.
    c <=(others => '0'); -- c ="0000"
    end if;
    case c is
    when "0000"=>Y<="1000000";-- 0
    when "0001"=>Y<="1111001";-- 1
    when "0010"=>Y<="0100100";-- 2
    when "0011"=>Y<="0110000";-- 3
    when "0100"=>Y<="0011001";-- 4
    when "0101"=>Y<="0010010";-- 5
    when "0110"=>Y<="0000010";-- 6
    when "0111"=>Y<="1111000";-- 7
    when "1000"=>Y<="0000000";-- 8
    when "1001"=>Y<="0010000";-- 9
    when "1010"=>Y<="0001000";-- A
    when "1011"=>Y<="0000011";-- b
    when "1100"=>Y<="1000110";-- C
    when "1101"=>Y<="0100001";-- d
    when "1110"=>Y<="0000110";-- E
    when "1111"=>Y<="0001110";-- F
    when others=>Y<="1111111";-- in other cases balnk
    end case;
    end process counting;
    B<='0';
    count<=c;
    end architecture Behavioral;
    you shouldn't use the push button as clock input, it isvery unreliable and sensitive to bounces, as you discovered.
    Instead, use a regular clock (I'm sure the board has an oscillator you can use) and monitor the pb signal on each clock cycle. You can detect a change on the button status by comparing the current value of pb with the previous one. You will also probably need to implement a delay for proper debouncing.
    Thank you Daixiwen!
    I see, anyway i tried to make a delay but nothing seem to work yet, still trying.
    I'm a beginner, so i'll will be really glad if you can help me with solving upon my code,
    to understand it better! If its not to much to ask!
    How did you implement the delai? I can for example have a counter increasing from the last time you detected a rising edge, ad you don't take into account a new rising edge before this counter reaches a predetermined value.
    Hi Daixiwen and thanks,
    Sorry for a long time no answer. Finally solved the problem. using the following code:
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity debounce is
    generic(
    counter_size : INTEGER := 19); --counter size (19 bits gives 10.5ms with 50MHz clock)
    port(
    Digit : out std_logic_vector (6 downto 0); -- 7 seg digit
    hex_count : out std_logic_vector(3 downto 0); -- Hexadecimal result
    clk, reset, button : in std_logic; --input signals
    Digit_en : out std_logic); -- 7 seg digit enable
    end debounce;
    architecture logic of debounce is
    signal counter : std_logic_vector(3 downto 0) :=(others => '0'); --initializing count to zero.
    signal flipflops : std_logic_vector(1 downto 0); --input flip flops
    signal counter_out : std_logic_vector(counter_size downto 0) := (others => '0'); --counter output
    signal counter_set : std_logic; --sync reset to zero
    signal result : std_logic; --debouncer result
    begin
    counter_set <= flipflops(0) xor flipflops(1); --determine when to start/reset counter
    process(clk)
    begin
    if(clk'event and clk = '1') then
    flipflops(0) <= button;
    flipflops(1) <= flipflops(0);
    if(counter_set = '1') then --reset counter because input is changing
    counter_out <= (others => '0');
    elsif(counter_out(counter_size) = '0') then --stable input time is not yet met
    counter_out <= counter_out + 1;
    else --stable input time is met
    result <= not flipflops(1);
    end if;
    end if;
    end process;
    process(result)
    begin
    counter <=(others => '0'); -- c ="0000"
    elsif(result'event and result = '1') then
    if(counter = "1111") then -- when count reaches its maximum(that is 15) reset it to 0
    counter <="0000";
    end if;
    counter <= counter+'1'; --increment count at every positive edge of clk.
    end if;
    case counter is
    when "0000"=>Digit<="1000000";-- 0
    when "0001"=>Digit<="1111001";-- 1
    when "0010"=>Digit<="0100100";-- 2
    when "0011"=>Digit<="0110000";-- 3
    when "0100"=>Digit<="0011001";-- 4
    when "0101"=>Digit<="0010010";-- 5
    when "0110"=>Digit<="0000010";-- 6
    when "0111"=>Digit<="1111000";-- 7
    when "1000"=>Digit<="0000000";-- 8
    when "1001"=>Digit<="0010000";-- 9
    when "1010"=>Digit<="0001000";-- A
    when "1011"=>Digit<="0000011";-- b
    when "1100"=>Digit<="1000110";-- C
    when "1101"=>Digit<="0100001";-- d
    when "1110"=>Digit<="0000110";-- E
    when "1111"=>Digit<="0001110";-- F
    when others=>Digit<="1111111";-- in other cases balnk
    end case;
    end process;
    Digit_en<='0';
    hex_count<=counter;
    end;
