19 years agoDE2 Quartus debounced circuit
Hello, I am working on a senior design project and have a DE2 board connected to external circuitry. There are pushbuttons on the external circuit which control leds also on that circuit board. M...
14 years agoyou shouldn't use the push button as clock input, it isvery unreliable and sensitive to bounces, as you discovered.
Instead, use a regular clock (I'm sure the board has an oscillator you can use) and monitor the pb signal on each clock cycle. You can detect a change on the button status by comparing the current value of pb with the previous one. You will also probably need to implement a delay for proper debouncing.
