19 years agoDE2 Quartus debounced circuit
Hello, I am working on a senior design project and have a DE2 board connected to external circuitry. There are pushbuttons on the external circuit which control leds also on that circuit board. M...
14 years agoHi Daixiwen and thanks,
Sorry for a long time no answer. Finally solved the problem. using the following code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity debounce is generic( counter_size : INTEGER := 19); --counter size (19 bits gives 10.5ms with 50MHz clock) port( Digit : out std_logic_vector (6 downto 0); -- 7 seg digit hex_count : out std_logic_vector(3 downto 0); -- Hexadecimal result clk, reset, button : in std_logic; --input signals Digit_en : out std_logic); -- 7 seg digit enable end debounce; architecture logic of debounce is signal counter : std_logic_vector(3 downto 0) :=(others => '0'); --initializing count to zero. signal flipflops : std_logic_vector(1 downto 0); --input flip flops signal counter_out : std_logic_vector(counter_size downto 0) := (others => '0'); --counter output signal counter_set : std_logic; --sync reset to zero signal result : std_logic; --debouncer result begin counter_set <= flipflops(0) xor flipflops(1); --determine when to start/reset counter process(clk) begin if(clk'event and clk = '1') then flipflops(0) <= button; flipflops(1) <= flipflops(0); if(counter_set = '1') then --reset counter because input is changing counter_out <= (others => '0'); elsif(counter_out(counter_size) = '0') then --stable input time is not yet met counter_out <= counter_out + 1; else --stable input time is met result <= not flipflops(1); end if; end if; end process; process(result) begin if(reset='0') then --when reset equal to '0' make count equal to 0. counter <=(others => '0'); -- c ="0000" elsif(result'event and result = '1') then if(counter = "1111") then -- when count reaches its maximum(that is 15) reset it to 0 counter <="0000"; end if; counter <= counter+'1'; --increment count at every positive edge of clk. end if; case counter is when "0000"=>Digit<="1000000";-- 0 when "0001"=>Digit<="1111001";-- 1 when "0010"=>Digit<="0100100";-- 2 when "0011"=>Digit<="0110000";-- 3 when "0100"=>Digit<="0011001";-- 4 when "0101"=>Digit<="0010010";-- 5 when "0110"=>Digit<="0000010";-- 6 when "0111"=>Digit<="1111000";-- 7 when "1000"=>Digit<="0000000";-- 8 when "1001"=>Digit<="0010000";-- 9 when "1010"=>Digit<="0001000";-- A when "1011"=>Digit<="0000011";-- b when "1100"=>Digit<="1000110";-- C when "1101"=>Digit<="0100001";-- d when "1110"=>Digit<="0000110";-- E when "1111"=>Digit<="0001110";-- F when others=>Digit<="1111111";-- in other cases balnk end case; end process; Digit_en<='0'; hex_count<=counter; end;
