16 years agoDE2 LCD BackLight
I have recently gotten the LCD to display text and numbers like I want, but I CANNOT get the LCD backlight to come on. There is a pin called PIN-K2 that is for the backlight and I have it set to VCC,...
16 years ago --- Quote Start --- Look at your LCD , on the right of it, there are pads of baclight --- Quote End --- Well, according to the schematic and user manual, the backlight - if present at all - is connected through the 16 pin connection rather than the dedicated backlight pins. The LCD module type referenced in the DE2 System CD datashet has a white LED backlight. But as said, there may be different versions. A visual inspection should clarify whats assembled to your DE2 board.
