15 years ago
de2 board minimum voltage
hi
could I operate the de2 board with less then 9 volt ?
    today I tried to burn again with two other cards
    one de2-70 and another de2-35
    I failed in both attempts ... is it even possible to burn with the
    as-programming mode?
    The programmer screenshot looks like AS programming has been succesful. In case of doubt, you are also able to verify the EPCS data. Sucessful programming doesn't imply, that the code is valid for the respective FPGA, however. But that's nothing we can help with. Did you try to run the same code through (volatile) JTAG programming?
    yes and it works
    I also check the verify checkbox and everything was ok
    but the board still remained in the previous state ( turn on on weak light)
